Thread: MPVI2 With Innovate LC2 issue
    Jan 2019
    Kansas City
    12
    Ive read thru as many post I can and still cant see the issue im having or how to correct it. Ive got the wideband to read in the channel side on the scanner but will not graph or chart time. Any one have screen shots of what the set ups are suppose to be? Or any one can break it down barney style setting up the graph and chart time.
    The LC-2 Parameter under transforms doesn't work?
    Jan 2019
    Kansas City
    12
    Quote Originally Posted by Jeff7577 View Post
    It works it in channel but nothing is showing on the chart time or histogram graph. It shows where I changed the name to WB on the chart time but when I make a run no line is drawn and on the histogram no numbers are being input on it.
    I'm using an LM-2 but have it set as a LC-2 to use lambda. I think i used the Generic Sensor "Eq Ratio" parameter for the chart and it picked up the Wideband from my channel setup.
