Results 1 to 3 of 3
Thread: Cammed Ls2 tune file review
    Apr 2019
    7
    Could someone look at my base tune file before i upload it. Newbie to tuning, just want to make sure it is ok for a maf only base tune. 06 vette, 233/239 cam, 102 fast, headers, no cats. Thanks
    06corvettecamtunemafonly2.hpt
    Mar 2011
    Ripley, MS
    1,865
    It's not a bad base file. Looks pretty conservative on the timing table. You'll probably be able to add a couple degrees timing at WOT.
    You will want to either desensitize the misfire tables or disable them completely with that cam.
    You'll also need to increase the min airflow table a bit at idle. I'd add at least another 20% airflow at low rpms.
    I'd reduce the amplitude of the Over/Under Spark tables as well.
    I suspect you'll be a little lean at WOT, but there's only one way to find out.
    Mar 2016
    12
    Thank You I used this as a base tune to get my idle tables for a comp cam 54-459-11 on a 07 LS2 C6
