Results 1 to 5 of 5
Thread: Running only one o2 sensor in downpipe on 2015 Mustang GT single turbo
    We recently built a turbo kit based on a 80mm Borg Warner we installed just bank 1 sensor in downpipe and I set sensor fitted to 1 in the tune but now I?m missing a lot of my scanner functions I can?t see mapped points knock and other channels. Anyone else ran into this issue?
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    Can you post a copy of the tune? I can take a look, don't know if I can help much but I have done this before and had no issues.
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
    Mar 2010
    27
    I ran into the same issue and couldn't figure it out. I ended up welding in a second bung and just run both sensors.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Ford does things differently from what I can tell. For instance when you switch flex fuel to enabled in the calibration it also will "unlock" additional pids in the scanner but you need to repoll when doing so. Going back to disabled you would need to again repoll for the correct pids to show. I assume its a similar case here and you would likely need to repoll since you are changing a big portion of the configuration.
    figured it out I needed to repoll the channels in the Scanner.
