Results 1 to 5 of 5
Thread: Cluster Fuel Density - Not Working? Adjusting For E10
    Advanced Tuner BigDaddyCool's Avatar
    May 2009
    Brisbane, Queensland
    767
    So has anyone messed with the cluster fuel density translation to adjust it for their fuel so the instrument cluster reads right for fuel consumption?
    It was 730,000 for the base rate, I've now got it set to 850,000 across the board and it still doesn't read right. I wish we could adjust the axies but I cant do....... it atleast than would be accurate for 98 or E10/94.....
    Last week cluster reads 14.1 liters per 100......... uses 15.9........
    2017 Toyota Kluger - 10.1" Android Custom Head Unit, Rockford Fosgate Speakers, 85kg Roof Racks. Prev: 2009 Cammed VE SS Sedan, DOD Delete, 210/218 550', RAMJet OTR, HiFlowCats, IQ System, Amp/Speakers.
    Jan 2014
    Australia
    1,979
    a lower number in table row increases usage shown, try 647,000 or im not sure on the exact scaling it works on so maby smaller changes till it is better
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    When I scaled for larger injectors on my 2006 GTO, it claimed I was getting 40 MPG. Since I cut the IFR in half, I halved the fuel density correction factor. It was still reading about 5% high, so I pulled 5% from the correction factor. It's extremely close to my hand calculated values from Miles and fill up volume.
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
    Tuner in Training jmanson62's Avatar
    Aug 2018
    Idaho
    18
    So the wife and I put our heads together to figure out the math. If 25% represents 744,705.875 and 0% represents 730,000.000 then 10% alcohol at the pump should use a number around 735,882.350. This is the number I put in my 0 cell and it helped with the fuel economy numbers on the display.
    May 2009
    767
    Cheers guys confirmed that worked ....... going the other way. Ended up around 710
