Page 1 of 4 1234 LastLast
Results 1 to 20 of 69
Thread: Little help with 2015 SRT 392 tune with Apache Max Cam and cat deletes
    Mar 2019
    MS
    78
    Stock the car was 419 to the wheel...With the cam I have gained 20hp but lost 28 torque...I have bought HP Tuners and the dodge beginners course and everything I have read says keep the NN but it has been disabled and a speed density tune done... What have yall done on the 392's with a small cam?
    May 2018
    36
    Some people tune different . Has the car been retuned after the modifications ?
    Mar 2019
    MS
    78
    it was tuned after mods...Advertised specs on that cam were 25/30 and I lost 30 torque
    May 2015
    1,908
    Full specs of the cam?
    May 2015
    1,908
    and post your tune, going to guess as with almost all vvt cams for the 6.4L, it will make the best power running fully advanced, hopefully that is how your vvt is setup.
    Mar 2019
    MS
    78
    intake duration 275 lift 554
    exhaust 281 lift 556 lsa 112
    Mar 2019
    MS
    78
    that cam was ground with a 4 degree advance already in it
    May 2015
    1,908
    sorry whats the duration at 0.050? advertised doesn't help much.
    its a bit of a misnomer....when we talk about VVT settings, running the VVT system "fully advanced" means the cam is being run at install specs. So in other words, to measure per the cam card if you are degreeing the cam, VVT will need to be fully advanced.
    Which again to my point, i wouldn't want that cam running any less advanced than the 4 degrees ground into it. VVT will only allow you to retard from there, which i think doin so will only make you lose power everywhere in the rpm band.
    May 2015
    1,908
    OH man i just looked at your tune, cam is being run fully retarded. 134* is considered fully advanced on the exhaust side, your tune is commanding 115* the entire way. You should be commanding 134* until about peak torque of 5280rpms, then retard it from there. Talk to your tuner, this doesn't look right. Makes sense why it made the power up top being fully retarded and explains torque loss down low. retarding the cam increases peak HP but kills low end torque
    Mar 2019
    MS
    78
    duration at .050 INTAKE 226 EXHAUST 230
    LOBE LIFT INTAKE 336 EXHAUST .337
    May 2015
    1,908
    Quote Originally Posted by ShannonSRT View Post
    Yea so lift wise its a "small" cam but those are healthy duration numbers for a 392, don't see it really benefitting much from running retarded. But need to redyno to see.
    Mar 2019
    MS
    78
    Your talking Exhaust Cam position where I see 115 all the way to 5280 right....
    Mar 2019
    MS
    78
    WOT desired angle right
    Mar 2019
    MS
    78
    Which it did till the very end of the rpm's
    May 2015
    1,908
    Yes and Yes. dodge calibration only uses exhaust side for all cam movements on the v8 hemis.
    Mar 2019
    MS
    78
    Quote Originally Posted by 06300CSRT8 View Post
    which it did until the very end of rpms
    Mar 2019
    MS
    78
    Im not bashing my tuner either...1st time he has seen that cam plus hes a LS guy for the most part
    Mar 2019
    MS
    78
    so there wouldn't be any clearance issues with the 134?
    Mar 2019
    MS
    78
    May 2015
    1,908
    As long as you have the phase limiter installed, as instructed, you can never have clearance issues no matter how off you make the tune.
