Anyone have a 2001 4.6L 4v stock read? Want to compare current tune to stock file.
What about an 03-04 Mach 1 5 speed?
Working on my car currently 5.1L stroker, 11-1 compression, Comp stage 2 cams, LT, 39lb injectors, LMAF
Only tune I have is an unknown procharger tune as a start as it was loaded in PCM. Looking to start from a stock tune and dial in from there instead of an uknown.
01 cobra ecu cannot run a mach1 cal without a lot of code changes
Good point. I was mainly looking for base line information. Timing Tables, parameters, etc.
Ill just run with what I got and dial in MAF and try and go from there. Thanks
i have a stock mach 1 tune if you still have any interest
wouldn't mind seeing it at all. Just to review the numbers
the same question
i need it!!!!
