Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Economy tune / Lean TuNE V8 Gen5
    Advanced Tuner Obsolete489's Avatar
    Feb 2017
    Yankton, SD
    299
    That sounds about perfect. Thanks
    2000 K2500 - 489 CI Vortec w/ comp XE270 cam - 0411 swap and rear mount turbo
    1972 M35a2
    2011 LML Duramax
    Dec 2019
    Boerne, TX
    117
    Quote Originally Posted by Russ K View Post
    I lean out the closed loop AFR. Set the Max Rich/Lean to 200 MV (ECM 2519)
    Russ Kemp
    What are the downsides to doing this? Do you know what this approximately equates to for AFR?
    Thanks in advance!
    SoCal
    1,558
    Quote Originally Posted by lucas287 View Post
    Thanks in advance!
    16:1 or close to it. Downside is potential hesitation or even misfire if it gets lean enough.
    Dec 2019
    Boerne, TX
    117
    ^Thanks! For the last couple days I've been rolling around with these settings:
    I don't notice any adverse effects yet, just great highway fuel economy. Didn't see much KR. Averaged about 23 MPG vs the usual 20. (pretty good for a CCSB 4x4 L86)
    Did you retune maf a little bit on cruise and low throttle parts ?
