Results 1 to 9 of 9
Thread: Slight starting issue at times.
    Tuner in Training moparsoldier85's Avatar
    Mar 2018
    41
    Starting issue after tune
    Had a company assist me with my tune but after looking through it i feel like they didn't tune as well as they could have. Starts very odd and sometimes she cranks for a solid 5 secs before it starts. Had the tune done after adding long tubes, comp 270 cam, ported heads (all new valve train) 6.4 intake rails and injectors. Cam timing hasn't been adjusted in the tune, anyone care to take a look i would appreciate the feed back.
    Mar 2018
    45
    Try multiplying your Startup Base table by .35 and Startup INJ PW Scalar by 2.32.
    May 2015
    1,908
    when does it do this, on hot restarts or cold?
    Mar 2018
    41
    It doesnt matter if its cold, hot outside or cold start or warmed up. Its odd like it starts but cranks for a few secs or even up to about 10 sec before it catches and starts. Happens very rare but just curious where to even look.
    May 2015
    1,908
    Its going to be startup inj pulsewidth table
    816
    How is fuel pressure at startup? Is the system losing pressure and has to prime?
    Mar 2018
    41
    Fuel pressure is solid
    Mar 2018
    41
    Quote Originally Posted by richhurley View Post
    Adjusted to these settings and it cranks for a good 10 sec trying to start but doesnt. Had to adjust back
    Mar 2018
    41
    I believe i figured it out. The tune i had unfortunately paid for from a shop didn't adjust anything in my cam timing so after reading through 06300CSRT8's post about adjusting the cam i tried that and so far it seems to be starting and even running better.
