Is there a setting somewhere that would allow be to calibrate the TPS reading?
To be specific a friend with an LS1 GTO (Gen 3 LS1B) is messing with his idle screw and IAC settings and asked if I could "re-center" the TPS to 0.5 volts which is recommended of whatnot after he finds his idle screw setting that is causing it to be off...??
TIA!!!
