Results 1 to 5 of 5
Thread: log file autosave?
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    log file autosave?
    is there any way to auto save a log file?
    only option is imperial and metric.
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
    13,559
    It already does with 4.0+.
    Mar 2018
    110
    I'm running 4.2.12 and it doesn't autosave anything.
    If I stop recording, disconnect from the vehicle and exit VCM scanner there is no log. I have to specifically go to save as, give it a name and click save
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    13,559
    It does, you are just looking in the wrong spot is all.
    Open the VCM scanner, click open file, click documents, click hp tuners, click VCM scanner, click logs.
    Mar 2018
    110
    Ah. I was looking under documents/hptuners/Logs and Tunes... Thank you!
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
