Results 1 to 20 of 32
Thread: 2500-3000 rpm weird lean condition 2014 ctsv
    Feb 2018
    824
    Have you guys with ctsv's seen this lean condition between 2500-3000 rpms? Does anyone know what causes it? You can see the fueling seems to become a little unstable around those rpms
    Jul 2018
    Texas
    214
    Is the fuel changing in reference to the o2 changes or due to another input? Could you have exhaust leaks? The screen shot does not allow for one to play the log. A log, charts, and some more setup info would be helpful.
    Aug 2018
    293
    I chased this for a while thinking I could fix it. No such luck. Didn't matter what I did- VVE boundaries with blended tune, maf-only with tuned VVE, maf-only with stock VVE, etc, etc. It always goes 0.03-0.05 lean (lambda) when you go through the 2500-2800 zone. I'd love to hear the fix if there is one. Others have had the same issue on this forum with no reported fix.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Quote Originally Posted by RobZL1 View Post
    the quick jagged changes in your 02 value are a missfire but that is only from your WB data, your NB02's dont show it however that may be due to them being at the lean side already.
    From the looks of it, it's one cylinder missfiring for whatever reason. Could it be overall general lean missfire? I doubt it. Where is the WB placed compared to your stock 02's? Left side, right side, looks like it's one or the other, not both.
    ZL1 Wheels/Tires
    Feb 2018
    824
    I was hoping someone who was smarter than me would have been able to fix it...lol. I tried everything you did too, maf only, vve only, blended and i still get it every single time...dammit.
    Feb 2018
    824
    Quote Originally Posted by 10_SS View Post
    If it was a missfire I would think i'd be able to feel it right? I have test pipes with my NB O2s in the locations that are on the pipe and my WB is in the 2nd bung on the drivers side. Passenger side 2nd bung is just plugged with one of the NB02 I'm no longer using (the one used for Cat testing).
    Feb 2018
    824
    Here is a snapshot of me into PE..I have seen these jagged edges ever since I installed the wideband. Car doesn't feel like it's misfiring at all. Next time i log i will log cylinder misfires to see if you are correct
    Feb 2018
    824
    I can't attached the log because it's too long...is there a way to shrink it or cut some of the drive off?
    7,607
    Use the +/- icons to zoom in to the duration you want to show (default is 30s each time a log is opened), then go to Log File > Export Log File, save the selection as a new filename.
    Feb 2018
    824
    Awesome, thanks for showing me that. I will do that and get the log posted
    Feb 2018
    824
    I've confirmed that those areas aren't misfiring. I realize the easiest way to fix this is have the map trigger for PE come in sooner, but that still doesn't explain why the car goes lean in this area. Especially when the maf/vve are within +/-2%. Any other seasoned LSA tuners have a fix for this?
    Feb 2018
    824
    2500 rpm lean condition.hpl
    Here is a clip of that lean condition happening again. It's not the same log as the screen shot i took, but it shows the problem I'm having. Does anyone know if it has something to do with the o2 sensors switching voltages?? I'm just guessing here...
    Feb 2018
    824
    I've logged misfires while going through that rpm band and there aren't any. I currently have b & b test pipes so my wideband is in the driversides 2nd o2 bung while the 02 sensors that control CL fueling is in the stock locations of those test pipes.
    Aug 2018
    293
    Just chasing a theory here while grasping at straws: has your car ever been tuned with a SCT tuner?
    Feb 2018
    824
    Any thoughts or ideas are appreciated. I don't think it has though. When I bought it back in 2015 and pulled the tune last year it had the stock tune in it
    Nov 2009
    All Around
    3,149
    log your inj PW and check that i dont see your file but maybe dynamic enable disable in those rpms?
    Feb 2018
    824
    Quote Originally Posted by SultanHassanMasTuning View Post
    They are actually in the channel list, but i didn't have them shown in the scanner. My dyn. setting are lower than that. I'll post my current tune shortly
    Feb 2018
    824
    current tune... thanks guys for the help
    Feb 2018
    824
    Here is my inj. PW shown in the scanner..doesn't look like anything weird going on in to my novice eyes
    Feb 2018
    824
    Here's another log that's a little longer that you guys can take a look at that includes my inj. PW
