Results 1 to 5 of 5
Thread: can't delete CEL (Permanent Cat Efficiency codes bank 1 bank 2)
    Oct 2017
    30
    hello
    i have tuned c63 AMG everything is great except the CAT codes as the car is decated,i have tried few ways to disable the codes and i made sure that there is no other codes in the TCM or ECU..they keep coming back again after time,
    i didn't have that issue with while the car was running someone else tune by WinOls
    Thanks,
    Sam.
    Senior Tuner BackyardTurbo_FTW's Avatar
    Jul 2009
    East Suckburg, PA
    1,149
    Besides just deleting the codes for specific faults there are also cat tests and downstream o2 tests you can disable in the engine diagnostic tab. Try disabling those and see if that helps!
    Oct 2017
    30
    thanks i will give that a try and update you
    Oct 2017
    30
    Hello,
    i have tried that and i still get CEL,
    that's the only codes the ecu is showing,i confirmed with different diagnostic tools.
    Jan 2019
    20
    I have issues with turning off the secondary air pump codes as well
