Results 1 to 10 of 10
Thread: Cant upload tune file to car
    Apr 2019
    10
    Hello
    This is my first post as i am new to this world and i hope i am posting in the right place.
    My problem is when trying to write the tune to the car it stops and a says timmed out and car cant even start after that,
    Then i pulled out the ecu and try to write it on a bench wiring and its fine.
    So WHY CANT I WRITE AS THE ECU ON THE CAR AND CAN WRITE THE SAME ECU ON BENCH WIRING?
    2003 GMC Sierrra
    MPVI 2
    28,275
    LIkely a wiring issue with the vehicle from the sounds of it.
    13,576
    Anything aftermarket on the truck?
    Like alarm or radio?
    Apr 2019
    10
    I still can read, scan and data log, is it possible to do all that with wiring issue?
    The only thing that i cant do is uploading tune file!
    Apr 2019
    10
    Aftermarket radio with RP5 adapter only
    28,275
    Quote Originally Posted by Tawashco View Post
    Absolutely, yes.
    13,576
    Remove the radio fuse and try again.
    Anything aftermarket like that is trouble with the 2003-2007 trucks.
    Feb 2006
    PAC NWest
    396
    I have that problem on a Chrysler. It begins the write with an erase, then times out. So I'm kinda dead in the water at that point.
    I found that if I disconnect the TCM connector from the ECM it writes fine.
    Apr 2019
    10
    I will try it and let you know
    Apr 2019
    10
    I found that the clock spring is damaged (open circuit). Could it be the problem?
