Results 1 to 19 of 19
Thread: new to making my own tunes
    Apr 2019
    hey guys! I just got my mpvi2 and am still very new to this. I was wondering if someone could share their tune with me so I can see what changes you made and how much. I just want to learn this safely and not change something too drastically and hurt the truck.
    my truck is a 2004.5 HO with an NV5600. Only mods are a MBRP exhaust and fass 150.
    Thanks in advance!
    Dec 2018
    Spokane, WA.
    11
    Have you tried the tune repository?
    Jan 2018
    658
    There?s lots of tunes scattered throughout the dodge diesel threads
    Apr 2019
    Checked the repository, they are all stock when I put in my truck. There's even one that says "race tune" but when you put it in as compare file with the stock tune, nothing is different. And I watched this forum for tunes for the week or so before I got my mpvi2 and didn't see any tunes, even tried to search for them but cant find a thread that has one. I'm sure that if I were to just comb through this place for hours I could find them, but I thought it might be more efficient to just ask directly-
    My truck is fairly modded, but i try to make modest tunes. After i put stock injectors back in and test, ill try and share with you. My tune wont be exactly what you want though. I tune for high altitude, large turbo, and auto trans. It is 04.5 though.
    Dec 2018
    Fortuna, California
    19
    The first tune that Dom posts in this thread is a great starting point and perfect for seeing where to start. I ran this tune for about a week, made some minor adjustments and ran for another week. At the time I was looking to do the same as what you?re asking. I am now making a lot more power running a completely different tune that I loosely based off of another one of Dom?s tunes.
    Dec 2018
    Fortuna, California
    19
    You?re going back to stock injectors? What size nozzles are you running now?
    Quote Originally Posted by Wgluv2hunt View Post
    They are new BMS 50hp from exergy. They smoke too much with my laggy large turbo and living at 10000ft. Too high and too cold up here.
    2004.5 Cummins. BW300sxe turbo, BD T4 manifold, BD CAI, 5" turbo back exhaust, turbosmart ext wastegate, BD lift pump with 2 mic filter and h2o separator, banks intercooler, Banks intake horn, slightly built tranny.......
    Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    80
    Noah what is the size is your turbo??
    Borgwarner 13009097047 s300sxe 63-73 compressor 63/80 super core turbine housing 80mm .83 A/R Twin Scroll Housing
    Sep 2018
    Quebec,canada
    80
    Its weird...i have a way bigger turbo than that with 100hp injectors and i have almost no smoke
    Jan 2018
    658
    Very high altitude
    Sep 2018
    Quebec,canada
    80
    It's not "tunable"?
    Jan 2018
    658
    More challenging
    Correct. Very challenging. 30% less dense air up here. Add constantly cold temps and it's a recipe for smoke.
    Sep 2018
    Quebec,canada
    80
    ya the damn cold temps.....it always play with coef/adder table...
    03 cummins,100hp nozzle,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    Jan 2018
    658
    All depends on where your tables are set at
    Sep 2018
    Quebec,canada
    80
    Mostly stock....want to keep the cold driveability
    Jan 2018
    658
    The correction tables only come into play to certain point then they are ignored in stock form
