Any plans on supporting the work trucks? I have a 2012, G56, CM2200, 12300230AK cal.
SOLD - 05.5 3500 5.9 | G56 | CM848 ECU | HPT "Pretty Fast" Tune | FASS 95 | Custom 5in Intake | Straight 4in |
SOLD - 08 F450 6.4 | 5R110W | Modified | ? Tow Tune | Custom 4" |
New - 12 Ram 4500 6.7 | G56 | CM2200 | RaceMe | Straight 4" | K&N Drop in
I had no problem with my 08 5500 C2100.
I think the CM2200 and 2350 are write only. I'm getting a check sum error, probably from the RaceMe.
Yes that will be from existing programmer. My h&s causes that also. Works fine if removed.
Tried setting it back to stock. Guessing it won't properly reset the check sum.
Ask for a recovery from RaceME. It?ll apply a pure factory flash to the ecm.
I have a stock file, its just in .ctz format.
.ctz is for EFI Live, not RaceME and isn?t the same thing or close to it, not even a pure factory flash file. Either a dealership reflash or a recovery file from RaceME is what you need.
The RaceME enters into a different bootloader to apply a pure unadulterated Chrysler flash file, no code patches or anything.
