Im trying to make my knock sensors trigger all the time, I built a stand alone display and I'm playing with couple of the PIDs so I want to see alot of knock to test it. All that works find and dandy.
I thought by changing the knock sensor settings in editor and flashing, I would start it up and see lots of knock retard in scanner, but I have nothing. It shows 0.0, I dont think it's any more sensitive than it was before. not even a little bit.
Did I go the right way here? I raised the 12960 Knock Sensor Treshold from 2ish to 50, that did nothing so I changed 12970 and 71 "knock threshhold Init" and "Min" way down, more than half for both.
Shouldnt these changes make the ECU think there's knock all the time? I get none in scanner, shows 0.0. I do get Burst Knock at tip in, but that is not what I'm talking about.
I really want to make sure Editor is still working, or if I'm doing something wrong or have something somewhere else not set right.
Thanks!
166 165 with knock sensors made very sensitive.hpt
