Results 1 to 2 of 2
Thread: dbw holds at 3krpm please help have searched
    May 2017
    9
    i need some help so this is a swapped truck 6.0 comp cam 4l80 dbw p01 setup drives fine light throttle trying to go over 3k or 50% tps vehicle holds miss fires and if i go wot will back fire thottle maybe it was fueling related but can't seem to figure it out tried going from sd back to maf thinking maybe that would correct the issue but it just holds and sputters i really need someone to look it over and see if i'm missing a setting need this truck running unfortunately the log i have isnt the best
    May 2017
    9
    Also immediate tip in sees a like popping
