I hooked up my 1999 Trans Am ECU to my bench harness and did some deletes (AIR, EGR, Rear O2), and tried to write the changes (Write Calibration) to my ECU. After about 5 or so seconds, it failed, and now every time I try to even just read the ecu, it says "Detect Protocol Failed". My harness is good, as I can read other ECUs just fine, but I'm really hoping that the ECU didn't brick on me 5 minutes after I spent 2 credits licensing it. I also let everything set disconnected overnight, hoping it would work after being off of power for a while, but no dice. Any suggestions? Thanks!
EDIT: I have also tried to re-synch my MVPI2, and that didn't help. I can't click on "Gather Info" and de-select the high speed option because gather info option gives me the same protocol failed response. Thanks!
