Results 1 to 15 of 15
Thread: No Throttle Response
    I went to a 2013 Roush tune. I changed all the things I thought was needed to get it going. It starts and runs just have no Input from the throttle. Is there something i'm missing? 2013 Mustang Roush Stage 3 FPFR0F4 PMAS ID1000 Throttle testing 1.hpt2013 roush test no throttle response.hpl
    Feb 2012
    TEXAS
    634
    whats the original calibration, 2013 GT? i cant check your file i am at work, but look at DBW info
    Feb 2017
    TX
    761
    You're getting MAF Sensor Saturation. Rescale your MAF vs PERIOD and I think you need to come up with new cell values too..
    Your throttle body data is not correct, It's a bad model. The angles are too large for the amount of ETC Area. I still think it should of had throttle response though.
    This is good throttle body data.
    the original file stock file is a 2013. I have been running a 2012 roush file. it runs good with it.I just don't have any of my track pack gauges or my cruise doesn't work. the car is a 2013 GT with a VMP gen 3 blower. Stock GT500 Throttle body ID1000 and PMAS cold air intake.
    here is the 2012 roush tune i have been running.
    2012 rousch test.hpt
    Feb 2017
    TX
    761
    So it does start up and drive? You're just not receiving any signal on the scanner? I thought you had a dead pedal.
    You don't have any of your trackpack gauges, cruise or throttle. There are some things I would change but I don't see anything in your file that looks suspicious of causing throttle problems you're mentioning.
    Yes with the 13 file that makes everything work. I have a dead pedal. If I go back to the old 2012 file it runs and drives. With the 13 file it cranks. I can watch the scanner. When I press the pedal nothing moves but the spark advance. The TP sensor never changes.
    Feb 2012
    TEXAS
    634
    Joey351,
    Are you sure that file is correct FPFR0F4, I dont show that calibration as a Roush file, are you Standard or Automatic i have FPFR0D3 calibration can you verify HERE roush DBW settings
    mstang_man I will look at it Sunday. I?m out of town at the moment. I really appreciate the help man. It?s a manual
    i got the file from 15 PSI. i have checked everything and still have a dead pedal.
    Apr 2018
    605
    Quote Originally Posted by Joey351sc View Post
    Are you still getting MAF sensor saturation? Did you check physical connections, wires, etc.?
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Yes sir i checked the plug and everything. Blackbolt22 im confused on MAF saturation. Is there anything else i need to look at?
    i got it. It was the MAF Default Period: Default period used for the MAF Sensor. it was set to 1,300. I set it to 70. Thanks for all your Help everyone.
    Oct 2016
    Poland
    1,738
    Dead pedal means problem in Driver Demand. Last time I had this they changed something in definition where the x and y axes were mirrored.
    That is why I do not recommend swapping strategies.
    Thanks veeefour
