Results 1 to 9 of 9
Thread: basic tuning questions
    There still doesn't seem to be a whole lot of support for these cars, as well there seem to be modifiers and maps missing. Recently we tried increasing the boost up to 22psi, this did take some time and the only table we found success in was ECM ID [14857], after increasing DC% by a seemingly unrealistic amount we finally achieved a maximum of 20psi (give or take a little depending on weather) I can't help but feel I'm doing something wrong. Attached is the most recent file on the car. If anyone has any pointers, it would be greatly appreciated!
    more bewst3.hpt
    Jan 2019
    NC
    54
    DC% changes are not needed at all to increase boost. I can't view the file myself at the moment but if you're having difficulty then chances are you're not familiar with anything in regards to tuning these cars and likely doing something wrong indeed.
    What do you feel is missing?
    What is the table you speak of?
    More than 20-21 psi is not going to be doable unless many maps are changed. But you should not go to or beyond this anyway unless you have the proper mods.
    What year and transmission? What all mods? What fuel?
    Quote Originally Posted by trdtoy View Post
    I've requested more load, raised pressure limits and anything else I saw that seemed related to load limiting that would prevent it from achieving more boost so I'm not 100% sure where I went wrong as when I started with the car I made small changes sequentially. It's a 2013, manual trans, intercooler, BOV, downpipe, on 93.
    Jan 2019
    NC
    54
    Quote Originally Posted by txtailtorcher View Post
    Not sure what mods you have exactly due to generic listing but especially on a 13 on 93 you do not need to push that much boost anyway. You also want the least boost spike possible to live a longer happy life. They'll pop quicker than the late 14 and newer VT.
    Now, a 13 VT with proper mods, fuel, and tune can still make good power but it takes more than it does on the late 14 and newer cars.
    If all you did was raise limiters to load and pressure to increase boost that is not a good idea. Many other maps need to be changed or you can get a higher boost at stoich scenario that will kill the already weak engine in the 13 VT.
    May 2019
    As trdtoy said, you should not be making DC changes to raise boost. I will look over the file when possible.
    If you could provide some direction I would appreciate it. The main request I've been hearing is "24" psi on 93 with meth.
    Quote Originally Posted by Xerxes1 View Post
    If you could please, I'd appreciate it.
    May 2019
    Request from who?
    Jan 2019
    NC
    54
    Screw requests, worry about safety. And 24 psi on 93 + meth is not safe on a 13 really unless highly modded which this car is not. 24 psi is not even great on a stock turbo either especially up top.
