Results 1 to 3 of 3
Thread: Charger RT auto Swap to manual issue
    Jun 2015
    Montreal
    50
    hi one of my custumer has bring me a charger RT 5.7 with a supercharger he swap the tranny to a Viper 6 speed manual tranny. I have put 800CC FID injector + a 450 walbro. The problem i have is in WOT no matter what i do i run in the 14-15 AFR there is no way i am out of fuel with those injector @ 10 psi only.
    Can somebody look over at the tune please of have an idea of what the problem might be? I already check the fuel pressure .
    What year is this car? Shouldn't you have your Pratio scaled for boost and the proper AFR?
    Mar 2018
    Illinois
    873
    Calibration details shows it is a 2007 5.7.
    Your WOT pedal threshold setting appears to be factory. Generally this should be set lower ~1.6-2.5V so PE can handle fueling when in boost. Also you need to rescale your tables for boost as Kmoney mentions.
    Also I see in transmission-general you still have A580 enabled, I would think you would want to disable this and enable manual trans, no?
    Are the motor internals stock?
