Results 1 to 8 of 8
Thread: Question about credits
    Potential Tuner nukem's Avatar
    Mar 2019
    West Union, SC
    9
    So, I had sent my ECM off for a mail order tune and I am not happy with it. It?s an extensive upgrade build on a 6.0 ls1 cam injectors and more...
    I decided to go the MPVI2 route and start from scratch. I pulled a stock 6.0 tune to work with and now I can?t write the tune to my truck? I guess my question is about how the licensing works? I used the vin change wizzard as well
    What am I missing here?
    28,262
    In order for YOU to tune YOUR vehicle using YOUR mpvi interface YOU would need to license the vehicle on YOUR mpvi interface.
    Licenses are linked to the interface so wherever the interface goes so do the licenses.
    Mar 2019
    West Union, SC
    9
    I?ve already licensed my vehicle. And performed several successful writes with the mail order tune already.
    Tuner in Training Nato1's Avatar
    Apr 2019
    Wasilla, Alaska
    22
    So it wont let you write a stock tune? have you tried just copying the parameters and rewriting it that way?
    Mar 2019
    West Union, SC
    9
    I copied parameters from the current tune over the stock repository tune before work but ran out of time to test it again... night shift this week.
    I think the problem is the license is based not just on the vin but the serial number of the ECM as well. That?s the part I was missing.
    The VIN change wizard obviously won?t change the ECM serial so a compare file copy over is the only way.
    28,262
    Please see attached
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Copy over differences from the file in the repository to your tune, if your writing the tune from the repository, it requires you to license that file to write it
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Mar 2019
    West Union, SC
    9
    Thanks guys. still learning with this.
    2004 Silverado 1500. 6.0 LS swap. 243 heads. Trick flow 30602003 cam. TBSS intake manifold. Long tube headers. And an MPVI2 to make it all work together.
