I'm looking for a stock tune for a late model LBZ 3500. The repository on has them up to 2500. I assume they would be the same for a 2500 and 3500 but I would like to compare just in case. Any help?
Anybody? I'm only looking for a stock file to compare with. Any thoughts on what might be different between a 3/4 and 1 ton?
Not as many 1 ton's out there but, as far as I know, the ECU/motor is the same. The 1ton is just a heavier payload.
2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
2010 GMC Sierra LMM Duramax. Exhaust and tuned
Where is the repository you a looking? I need a stock tune.
Main HPT page. You can access when you log in from your account page.
