Thread: segment swap
    Dec 2018
    Washington State
    182
    segment swap
    I just swapped in a 4L80 in to my 2003 Tahoe, I'm running a 2 bar OS can I swap without going back to the original OS? I've read where you can but I want to be sure before I do it.
    13,565
    Haven't seen it done with a 2 bar OS yet. Not without a write entire from another file, but that's not what you want to do.
    Just do the segment swap on the stock file, then apply the 2 bar OS again and copy over all your information with like 5 clicks using the compare feature. Should be really straight forward.
    Dec 2018
    Washington State
    182
    I did the segment swap and now I don't have any throttleTahoeonebarsegmentswap2bardatacopied.hpt no codes are set
    Dec 2018
    Washington State
    182
    Solved, I did another write entire and it now works....
