Originally Posted by
TCSS07
it looks like the tune can use a little tlc on the fuel trims side at least. your pretty rich in the cruising section. Read up about maf tuning and ve/vee tuning. but what i would do first is go under engine diag - airflow and for test p0101,p0106,p0121 set min ect to 493 and test p0068 set enable rpm to 8k. Because of the mods your probably freaking out the ecms internally parameters for airflow correlation between the tb,map and maf. turn off cat test and post o2 test. those can command weird afrs whenever it wants to. thats under exhaust in engine diag and you still have some torque management still enabled (spark retard and torque loss %) under torque management - general
