Has anyone here done the swap with the ck performance D3 valve body? what am i missing? the issues I am having is the scanner is showing in the D1 position but the current gear shows 2nd. and my speedo is only reading half the mph that i am really doing, so I am wondering if i am missing a setting for the second speed sensor. I did do all the wiring conversions at the trans plug as well as the ecm.
I am running a 26" tall tire, aparently i didnt know i had to do a segment swap so i am doing my research on how to do it , but i am running into an issue finding a match to my OS
Ok so now i have done segment swap is there anything i need to change in the settings, to make it work with the Ckperformance D3 valve body? I only ask since with the D3 you have to disconnect the EPC wire from the ecm , cause with this valve body that wire is now the trans brake activation wire and the trans pressure is set at 220psi in all gears.
