your still reading air fuel ratio commanded instead of eq ratio commanded.
your wideband is reporting lambda and your ecu is reporting afr.
in order for the fuel error math to work these must be the same. now its up to you to choose but i would run lambda error if you do anything that is involving ethanol.
so leave your wideband in lambda but now delete the commanded afr channel and use commanded eq ratio (which is lambda) as your ecu reporting pid.
