Results 1 to 3 of 3
Thread: 05 magnum rt built 6.1 swap tps issues
    I built a 6.1 and put it in my 05 magnum rt
    I got a 6.1 tune and tweaked it
    For some reason I only get 86% tps at max throttle
    With stock throttle body 85mm and my 90mm
    New pedal
    But the 6.1 tune I'm pretty sure I was seeing 98 to 99% at work
    I cant find my 5.7 data log to recheck
    Does anyone have the tps voltage tables for it to be right am I still actually getting full throttle but just showing 86%?
    It's a beast now on 200 shot
    But if I'm missing 14% throttle!
    Are you looking at the pedal percentage or the actual Tbody. Anything over 75 percent for Chrysler is considered WOT. But as always.... Post the tune and log..
    Tps in vcm scanner log
