Results 1 to 3 of 3
Thread: Fuel pressure
    Apr 2019
    11
    Fuel pressure
    Is the fuel pressure in the scanner accurate? If so, where exactly does it read it from?
    13,564
    Not in a gen 3. They don't have fuel pressure sensors in any of the LS1/6 or the truck engines. None that I've seen before.
    The later cars with fuel pump control modules can let you see fuel pressure.
    Apr 2019
    11
    Weird because my scanner is showing between 28 and 35 psi which I know is way to low. I just couldn't figure out where it was coming from. My AFR is showing pretty lean though. I'm going to put a tester on the rail though and go from there.
