Results 1 to 9 of 9
Thread: LC-2 will not chart correctly
    Apr 2019
    richmond, VA
    31
    I am pulling my hair out here trying to get this to chart correctly my air fuel is at 14.5 -14.9 at idle under boost its 11.3 - 11.5 PLEASE HELP ME1st run.hpl
    Apr 2019
    richmond, VA
    31
    You need to go to charts layout---transforms---oxygen sensors---LC-2
    Apr 2019
    richmond, VA
    31
    Thank you so much, I?ll try that this afternoon.
    Apr 2019
    richmond, VA
    31
    That?s exactly how I set it up. In my channel it shows 7.7 and on the chart it shows the same while my air/fuel gauge is reading 15
    It could be the output from the LC-2 is set to something other than gasoline.
    28,265
    Quote Originally Posted by Jeff7577 View Post
    That sounds like a pretty reasonable answer^
    Apr 2019
    richmond, VA
    31
    Ok, so I?ve found that there is a problem with the LC-2 output. I gentleman named Corey checked and said everything was set up correctly on my chart side so I?ve got to figure out what?s going on on the other end. Thank you guys for the help. I really appreciate it
    Apr 2019
    richmond, VA
    31
    Just for the extra info, I had to use the LM Programmer to change the output of the output #2 to match the output 1#. #1 is used for the gauge leaving #2 which is set up different. Very easy change works beautifully now.
