Results 1 to 4 of 4
Thread: Dual DBW setup on E38
    Hello all,
    Seeking some advise on a dual DBW setup with my e38 PCM. Running a L77 and 6L80e, but want to do a dual DBW setup in keeping with the look of the truck it is going into.
    1) Has anyone done it yet using the e38?
    2) What was the process/products used? Torque Rush "x2"? Ozmo Engineering "2TB"?
    More technically, what is the input/output to the throttle bodies which prevents it from simply being wired in parallel? I assume the e38 would not like the idea of mixed signals coming from twin throttles.
    Thanks in advance!
    ~Ryan
    Charleston, SC
    Mar 2011
    Ripley, MS
    1,865
    Hi Ryan,
    It seems like you should consider a Holley Dominator. Their dual DBW setup works nicely. I just tuned one last week that did great in a similar application.
    It would also drive your 16 injectors.
    Good luck.
    Kevin
    Quote Originally Posted by kevin87turbot View Post
    Hi Ryan,
    Good luck.
    Kevin
    Only issue there is that the dominator does not have 6L80E control capability.
    ~Ryan
    Charleston, SC
    Any further inputs? Am i stuck with the TorquRush since Ozmo is not producing any products at the moment?
    ~Ryan
    Charleston, SC
