I'm tryin to use a e38 as a standalone and everytime I try to start it there's no fire and throws a crankshaft not learned code.. I've disabled vats 1 and 2 ..... Even tried it on my 09 suburban and same thing. Think it's a bad computer?
Did you disable both VATS patches and then Write Entire? In a standalone application, you'll also want to change the starter diagnostics parameter in System->General->Starter Relay to Disable.
The Crankshaft position code is expected when a different ECM is installed, once the engine is running perform the Crankshaft Position Relearn procedure.
~Erik~
2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
Got it figured out! Thanks
