Results 1 to 7 of 7
Thread: Can Speed Density 3 bar, be easily returned back to "Normal" MAF/VE setup?
    Feb 2008
    Baltimore, MD
    221
    Question Can Speed Density 3 bar, be easily returned back to "Normal" MAF/VE setup?
    Car is a 2000 Trans Am with a 2002 Silverado PCM...I guess because car has/had a 6.0 and 4L80E and it may have been a way around or something??
    I do NOT have the stock, original file. Car was built, and tuned by someone (unknown) long before I took possession.
    Car WAS turbocharged, but now it is NOT...so I have absolutely no need to run a 3 bar SD setup.
    Anyway, it has a 3 BAR SPEED DENSITY (RTT) OS now, and I have TWO questions regarding that...
    1.) Since this is a SPEED DENSITY specific operating system, I "assume" the MAF is hard coded OUT of the equation???...if that is not the case, should/would/can I simply RE-ENABLE the MAF settings, if I wanted to run a MAF meter now???
    if NOT,
    2.) Can I do a WRITE ENTIRE or something, to go back to a traditional MAF/VE setup??? (again, I do NOT have original file)
    The reason for these questions, is that turbo is long gone, and I have tried, unsuccessfully to run a conventional MAF/VE setup using what I have.
    Here is what I currently have....
    2000 Trans AM WS6 6.0, 4L80e, 9"
    2008 Silverado LT 5.3 liter Work Beater
    Aug 2009
    Calibrating
    3,373
    Yes you can
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Feb 2008
    Baltimore, MD
    221
    Quote Originally Posted by Ben Charles View Post
    Yes you can
    I can...............what?
    The MAF, when enabled, does not function properly, ie; afr is all over the place, chasing my tail.
    I'm trying to determine if there is another issue.
    Dec 2011
    San Antonio, TX
    319
    Either write entire a stock file from the repository of have someone with a tech2/MDI type device and SPS subscription to flash a stock OS back onto it.
    The gen3 custom OS stuff does not use the MAF as far as I am aware. The gen4 custom OS can still use it.
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    Aug 2009
    Calibrating
    3,373
    You can write it back to a stock OS
    I have had success using MAF on the custom SD gen 3 operating system as well (even though it says SD only)
    14 Gen 5 Viper
    Feb 2008
    Baltimore, MD
    221
    Thanks for the replies guys.
    13,564
    I've run the MAF in a upgraded speed density OS before too.
