Results 1 to 2 of 2
Thread: Help with 01 C5 4L60E
    May 2019
    1
    Okay, so I recently purchased Dan Maslic's book on GM Tuning. It was a good read and I am very comfortable with the engine tuning portion however I feel there could have been more information regarding tuning 4L60E settings. The car will soon have a cam swap using the stock 4L60E and stock converter. I am primarily looking at torque management portion of the file. In the Maslic's material it says to reduce the torque reduction by reducing the Torque Reduction Normal table under the Torque Management tab in the Transmission section. I am wondering what changes should be made in the Engine section under Torque Management i.e. should I increase the Max Torque Value, increase torque values in the Max Engine Torque .vs. RPM .vs. Gear, and should I reduce Spark Retard .vs. Torque Reduction. I feel there's a lot of questions that go unanswered as to tuning these parameters. I've searched a lot and can't find anything conclusive.
    Dec 2018
    Washington State
    182
    post your tune.
