Results 1 to 18 of 18
Thread: 2019 Jeep JK ProCharger HELP NEEDED PLEASE!
    Tuner in Training 1278342005's Avatar
    Oct 2017
    Norman, Oklahoma
    27
    I have a 2019 Jeep Wrangler JL with a P1 ProCharger on it. The dealership dropped it off with little to no information and said tune it. I finally found out that it has a SRT4 Map sensor in it and Fast 60 Fuel Injectors. I have NO idea how to scale this for the SRT4 Map as there isn't any data out there that I can find. HELP PLEASE! The Jeep starts and runs but it starts in limp mode and I can't figure out how to get it to communicate with the trans. It kicks a TCM communication error and Low Barometer codes.
    Last edited by 1278342005; 05-31-2019 at 01:36 PM. Reason: Mistake on Type of Jeep
    378
    Did procharger provide any sort of base tune?
    Feb 2016
    318
    Look in this thread, should have some of what you need..
    https://forum.hptuners.com/showthrea...charged-Issues
    Oct 2017
    Norman, Oklahoma
    27
    ProCharger doesn't have any base tune for it except for through DiabloSport and it is for only a BASE kit without any modifications. There aren't any parameters available for the SRT4 Map sensor they say they're using. I can get it to idle fine but there is zero throttle and the only CEL is a Low Barometer now.
    Oct 2017
    Norman, Oklahoma
    27
    Quote Originally Posted by Hemituna View Post
    Yeah I saw this thread and it is for the 2014's. They changed quite a bit between the two and it seems there really isn't any support out there for them.
    Feb 2016
    318
    Same same but different...just a later OS
    Mar 2018
    38
    For the 2 bar SRT4 Map sensor try the following:
    Under Engine -> Airflow -> General
    MAP Sensor Linear - 46.38 kPa
    MAP Sensor Offset - 4.80 kPa
    PRatio Max - 2.000
    PRatio Max Turbo - 2.000
    Disable Baro Fine Tune and Learning
    Enable Sensed MAP
    Under Engine Diagnostics -> Airflow
    Max Tip Baro - 20.0 kPa
    Max Tip MAP - 20.0 kPa
    Baro Voltage Min 0.12 V
    Oct 2017
    Norman, Oklahoma
    27
    Quote Originally Posted by richhurley View Post
    PRatio Max - 2.000
    Enable Sensed MAP
    This worked! Thank you!
    Jun 2019
    16
    I am having the same problem finding data. Do you have the part number for that two bar sensor so I can try that sensor and data as well? I have a srt4 2.5 bar sensor according to sprintex superchargers. Only running 10lbs boost so i believe that should be fine. I think lol. newby here.
    14jeepwranger3.6
    sprintex sps supercharged
    i believe there's only a 2.25 bar sensor. so when sprintex says 2.5, they aren't exactly right and original poster saying 2, same thing. settings for 2.25 you'll find in a stock 2003 srt4 file from the repository. there's also an srt4 3 bar map sensor and this is often used too. you'll find the settings for that from a 2005 srt4 file. you can find the part numbers for both with google.
    Apr 2014
    607
    Quote Originally Posted by caenews@hotmail.com View Post
    Just a minor correction here, but important nonetheless. 2003 through 2005 Dodge Neon SRT-4 all came stock with 2.25 bar map sensors. The Neon had a Mopar S2 or S3 kit that would add a 3 bar map sensor, which was available for all 3 years (2003-2005).
    In 2008, the Caliber received an SRT-4 trim level package which came stock with a 3 bar map sensor, but was not the same sensor as what was supplied with the Neon Mopar S2/S3 kits. The map offset kpa value of the Neon SRT-4 Mopar S2/S3 kit is 6.8 kpa, while the map offset kpa value of the caliber SRT-4 is 7.0 kpa.
    Here are the visual differences between the 2 map sensors:
    Neon SRT-4 3 bar map sensor (looks identical to stock 2.25 bar map sensor)
    Caliber SRT-4 3 bar map sensor
    Jun 2019
    16
    The sensor I have looks like the bottom sensor with one bolt hole. I have a Bosch 0 261 230 283.
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    81
    Quote Originally Posted by B00STJUNKY View Post
    The prodigy turbo kit uses the 3bar from a caliber and this is what I mainly see people using on modded Jeeps - 61.85kpa 7.0kpa 0.10v
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    Next Level Tuning and Performance
    Mar 2018
    38
    Data for the Bosch 0261230283:
    Pressure Range .2 - 2.5 Bar/20 - 250 kPa
    Voltage Limitation 400-4650 mV
    Jun 2019
    16
    Thanks, Bosch couldn't even tell me that!
    Jun 2019
    16
    Is the MAP Sensor Linear 54.65 kpa, MAP Sensor offset 20.00 kpa, MAP Sensor offset .041v by any chance on the bosch 0261230283?
    Mar 2018
    38
    Quote Originally Posted by BULLETPROOF View Post
    Linear - 54.12 kPa
    Offset - 5.80 kPa
    Offset - .10v
    Jun 2019
    16
    thankyou!
    Linear - 54.12 kPa
    Offset - 5.80 kPa
    Offset - .10v
