Results 1 to 6 of 6
Thread: crankshaft position system variation
    May 2019
    5
    Hi
    I have a 2012 cmaro ls3 engien and swapping it in to a 67 nova.
    have it on an engien stand trying to get Everything to work
    Before putting it in the car.
    The engien starts for 2 sek then shouts down,have a dtc p00315 crankshaft posision system variation not learned
    is this the reason for the cut out?
    Running out of ideas have disabled all funktions that i will not use.
    claes Sweden
    Hi Everybody
    I am Writing again to tell evrybody that my issue is solved,i bauoght a
    used ECM on ebay and that solved the problem.
    So i had an issue with the ecu without knowing.
    Jun 2011
    MARKHAM,ON
    77
    Have you disabled VATS under OS?
    May 2019
    5
    Hi
    Yes vats diabled only one strange thing is after updating
    hp tuner to the latest version i no longer see that option in
    the OS tab?
    Jun 2011
    MARKHAM,ON
    77
    I had thought I disabled mine, however I didn't hit upload or whatever it is you hit to program the ECM.
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by tigersimone View Post
    Very unlikely.
    I have installed several swaps and they run correctly when that code sets. For stock or mild engines you can even shut the DTC off without issues.
    9 sec Montecarlo SS
    May 2019
    5
    Hi
    Iread somevare tha a low oilpressure cut cut the injektors?
