Results 1 to 6 of 6
Thread: ABS/Track control/ Brake light on after tire change
    Sep 2016
    4
    IS there a way to get my lights to not come on anymore.
    Went from factory 275/40/17 (approx 26") to 295/55/15 (28")
    Front and rear tires are VERY similar in size height wise.
    I used HP to adjust speedo for tire sizes change. MY local show tried to use a Tech II to see if they were able to adjust anything and could not find anything.
    LEt me know Thanks
    Can't do much without knowing what code is setting but i'm sure its front/rear speed mismatch. Hp tuners can't do anything with the ABS module.
    Sep 2019
    Jeff, Do you know any other tuners or other way to modify abs settings? I need to change the rear wheel speed sensors on a 2013 camaro from 38 pulses per revolution to 55 pulses per revolution. Want to scale the pulses per wheel rev in the EBCM if ppossible. I am removing the IRS and replacing with a solid axle.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Some ecus have an abs output that is specifically for this issue. It is under the speedometer calibration tab
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    7,618
    In the Tech2, look at:
    Chassis > ABS/TCS/VSES > Special Functions > Tire Size Calibration.
    Downside is you can only choose from a predefined list, and it's in 'Pxxx/yyRzz' format, you have to work backwards to find a size with the diameter you need. And the sizes in the list cover a certain range, you can't input the size you want directly.
    Aug 2016
    Brooklynville
    11
    Quote Originally Posted by mbray01 View Post
    Which way to start if larger Dia tire was installed?
