So I just recently wrote a 2012 Silverado OS with the 2 BAR SD patch applied to my 2011 head/cam/turbo 5.3 GMC. I transferred all my data over from my original tune other than the new tables that are in the 2012 operating system that weren't on the 2011. The issue that I am now having is that when I disable the MAF, it does not want to idle. It will surge until it eventually dies out or if I give it some gas and slowly let out it will stabilize. Also, when I put it in gear or turn the A/C on, it does the same surging thing. As soon as I re-enable the MAF everything is fine again. One thing that I noticed when logging it is that when the MAF is disabled the TPS is around 13% while trying to stay running but with the MAF re-enabled the TPS is around 19% and it idles fine. I tried adding a few grams to the minimum airflow table but that did nothing and I tried adding more fuel to that part of the VE table and still no luck. Where should I be looking next? MAF Disabled.hplMAF Enabled.hplOL.hpt
