I have been dialing in drivability on my 426, 2.9 whipple build. One of the main things I have been dialing in is the transition into boost and also staying out of boost when it's not desired. To do this I have scaled my large throttle tables under feet forward control, the cars feels damn near NA until I really lean into the pedal now and drives so smooth and goes into boost with a factory like feel.
For the Throttle Body Model I simply added 28ish percent from top to bottom as that roughly the difference from the stock TB to the 102mm I run.
However sense doing this I often get a "bank 1 and 2 lean" my assumption is because I have more air entering the car and the pedal not reflecting it? I would honestly rather turn the codes off then go back to the old tables, but wanted Input from others. Anything else to check out?
