Results 1 to 6 of 6
Thread: Tune ok to use
    Feb 2017
    Billings,MT
    97
    Tune ok to use
    I followed the ramjet tune and used the calculator! Could someone please check this out and see if it's safe to use? Truck has 4" exhaust and modified intake.
    Thank you!!
    Feb 2017
    Billings,MT
    97
    Opinions...PLEASE!!
    Advanced Tuner JaegerWrenching's Avatar
    Jun 2018
    Albuquerque New Mexico
    465
    what did you use to deleted the truck with? Looking at the file now.
    Jun 2018
    465
    Looks fine, that's a small amount of fuel change in your tq based fuel map IMO, don't be scared to go to 125ish @811tq column so you take advantage of your injector PW increase. Log your PW and see what it's actually hitting and then adjust timing based on that. I'd be surprised if you really feel a whole lot form these changes without increasing tq based fuel some more. Also you need to change your smoke limiter under main injection limits to .80 around 1400rpm-2800 and from .65 airmass to 2.4, just my two cents so it's not limiting you. If you add fuel be sure to go back to your Qty vs rpm factor and adjust it so it doesn't limit.
    Feb 2017
    Billings,MT
    97
    Quote Originally Posted by JaegerWrenching View Post
    Is this one any better?
    Jun 2018
    465
    Here ya go, Try this, but don't tow with it until you know what EGT's do while under constant load! Daily driving it's fine probably even for towing but i can't guarantee that. Your Timing is going to be done by you and what you're actually seeing for injector PW. Keep it at a 50/50 in higher load areas.LBZ85hpCHelp.hpt
