Results 1 to 4 of 4
Thread: 6L80 issue
    Feb 2012
    5
    6L80 issue
    Hello,
    i have 2012 Escalade and have "issue" at about 2200rpm in 2 gear before it shifting to 3 gear and with part throttle in about 44%. At WOT is all good.
    Was on stock cal and cant find how to "fix" that.
    Logged and only see throttle closing with accelerator same position - log file attached - it starts at 9:56:07.
    Dont think is TM related.
    Can anybody help me? I think i am not alone with this.
    Feb 2012
    5
    Stock cal attached.
    13,565
    Can you describe the issue, I guess I'm not sure what I was suppose to be looking for in the log.
    At 9:56 in the log you are doing like 80mph, so that isn't 2nd gear.
    Feb 2012
    5
    I am so sorry, my mistake, correct time is 5:52, at 46kmh.
    I can describe - when you will start with mid load or you will leave corner at mid load it looks like gear change to same change - you can see throttle closing, not full but closing and after few hundred rpms will change gear to 3.
    Will log better.
    Thank you
    2012 Cadillac Escalade ESV Platinum
    2006 Dodge Magnum R/T
