Results 1 to 5 of 5
Thread: OS 2 Bar change and instrument cluster???
    Apr 2019
    Texas
    30
    I swapped a 2005 truck with a 4.3 to a turbocharged 2006 5.3 with a 4l80e. After I changed operating systems for the 2 Bar my gauges are way off and most of the dash lights are on. Why would changing to a 2 BAR cause my gauges to be incorrect. I used the 5.3 PCM should I have used the 4.3 PCM or is this a different issue??
    Any help would be great.
    Thanks.
    13,565
    The 4.3 trucks were drive by cable and the 2006 computer you have is drive by wire. Maybe it has something to do with that?
    Apr 2019
    Texas
    30
    i don?t think so it was working fine until I swapped to the 2bar OS. I Thought about going back to the other OS but figured there?s no real point.
    May 2019
    new england
    74
    do you have the original file from before the 2 bar? open a compare? im new just throwing out an idea
    Apr 2019
    Texas
    30
    Ya I tried doing that to no avail, i'm not really sure what the issue is. Appreciate the reply.
    05 Silverado Single Cab Long Bed
    LM7
    VS Racing 7875 12 PSI
    E85
    Snow Stage 2 Meth
    BTR Stage 2 Turbo Cam
    Built 4l80E
