Afternoon all. I recently fitted a single turbo to my 2013 Silverado 5.3.
I carried out an OS Change to the 2 Bar operating system as its the only one that pops up. Issues are since entering all VE info, map offset values etc the vehicle will not run in SD mode. It fires and then dies. Noticed Inj pulse on crank is good, but once it fires up it drops to .5ms no matter if I touch the throttle or even force a higher value. I switch over to maf only setup and the car runs fine. The two logs are attached. Cross referencing data I see the engine torque is minus in OS 2 Bar SD mode and positive in OS 2 Bar maf only. Not sure if this has something to do with it. If I switch the OS back to original, I can run SD mode with no issues. I have looked at the tunes and believe I have switched over all relevant information to the OS change. Any advice would be appreciated.
Thanks.
