Results 1 to 10 of 10
Thread: spark retard issue silvrado 2011
    May 2006
    K.S.A
    46
    Angry spark retard issue silvrado 2011
    hello there
    I have an issue with this car it's retard the advance up to -20
    I can't see the problem ?!!
    see the log in attachment
    May 2006
    K.S.A
    46
    any thoght guys ??
    Post your tune. Why is it at 228 degrees?
    May 2006
    K.S.A
    46
    it's stock file i did't tune it
    May 2006
    K.S.A
    46
    abo waleed HD.hpl
    any Pro tuner can tell us where the problem is ?
    In the attachment log file
    I saw the MAF reading goes highter.
    May 2006
    K.S.A
    46
    stell looking...
    May 2017
    Are you able to post the tune file?
    May 2006
    K.S.A
    46
    Sure
    see the attachment
    13,559
    You need to log all the channels that relate to spark timing.
    Anything that can pull timing is what you need to be logging. So any of the spark correction tables like the IAT, ECT, torque mngt.
    I can already tell you strictly based on the last log you are losing 13 degrees of timing from the IAT temps. The temps are around 125-135 degrees and that IAT spark table is pulling 10-13 degrees.
    I've never seen a command idle speed of 361rpm before either. I'd try asking for 600rpm all the time when it's warmed up too.
    May 2006
    K.S.A
    46
    thanks for lighting I'm working on it
