Hi, took it for a run this morning and got a good run at a hill and log shows PE is a bit rich, so how much should I take out and is it all the of it ??
Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
I would drop the PE enable rpm to 2500 and reduce the WOT fuel by 5%. That will put you in the mid 12's.
Many thanks for that, will try it next time I get a car day , john
