Okay,
I'm not a computer neophyte by any means, and I thought I had things worked out to log transmission stuff, however I'm missing something apparently.
I have searched this site, and looked through the help files, but apparently my keyword searches don't yield a "how to" for logging transmission data.
I don't believe it can't be logged because if HPT has the Tach, and SPEEDO working on the "dash display" it shoudl have all the data it needs to show me the others.
Here is what I have tried.
I pop open Chart Display, then in Table Two Tell it to Log Trans input Shaft, Trans Output Shaft, TCC Slip % and TCC Slip RPM. The table defaults the loging to 0-0 so I change it to 0-6200, 0-6200, 0-100, and 0-6200 respectively.
When I drive it doesn't log any data.
I also found that if I pop open the "Table Display" view there is the ability to delete the MAF & MAP from the PID, however I can't add the Transmission ones because I'm exceeding 24bytes.
Can someone please point me to a help file, or something that will help.
Yeah, I'm using a relic version 1.6 of HPT.
Thanks in advance.
