2009 C6 Z06 heads cam with DSX Tuning flex fuel kit, and 49.9 lb/hr L9H injectors. Car ran well on the dyno with 91 e10. Made 545 rwhp 450 rwtq on dyno dynamics hub dyno. When we switched to e85 (ended up being 65% after mixing with fuel in tank) it kept going lean at 4000 rpm. Logs show PE enabled and commanding .854 lambda EQ, but the wideband begins to ramp to 1.00 lambda right above 4000 rpm. Fuel pressure was good throughout all the dyno pulls. 2009 E38 operating system 12628988 only has EQ Ratio (Gas). HPTuners tech support says this operating system does not have EQ Ratio (Alcohol), however it is obvious in the datalogs that something is commanding the EQ ratio to 1.00 at what I suspect is 4096 rpm. I can find nothing in the editor that corresponds with this to correct it. I suspect there is either a setting or table I am skipping over, or there is a table in the operating system not accessible that needs tuned. After having this problem we emptied out the e85 and put 91 back in. This got it back to 18% ethanol, which we made another pull with and had no problem with the PE. Attached is the tune (which has some minor changes since the logs), and logs (2 with 65% ethanol and PE problem, and 1 with 18% ethanol and no problem). Has anyone else experienced this issue? 2009 Chevrolet Corvette Z06 7.0L Dyno Tune 4-27-2019.hptpull 9 18% 580 degrees.hplpull 7 e85.hplpull 6.hpl
