I am trying to get the segment swap to work. It will not highlight. I watched a few videos, read and searched. I have updated to latest version. I have the MPV1 pro. I have licensed my the computer. I am stuck any help is appreciated.
Would be helpful if you posted your file and the file you are trying to segment swap with.
Can't help you without you helping us with that information.
I will add here, that whatever you are trying to segment swap with MUST have a matching OS. Otherwise it will not let the swap work.
thanks for the info, im looking for a file for a manual os 12202088
I personally wouldn't recommend segment swapping from an auto anything to a manual, it rarely works out well as there is alot more to an automatic cal than you can see in the foreground. Usually best to simply have the ecm flashed with a manual file and start with that as your base.
Its one thing when going from 4l60 to 4l80 but a completely different animal when going from a 4l60 to a manual.
