Results 1 to 5 of 5
Thread: MAC Install
    Mar 2010
    Texas Hill Country
    3,161
    MAC Install
    Have had Race Render for a long time, several years, never had an issue downloading and installing on my imac. got a new imac, downloads, runs through installation, but no icon in Applications folder, can't find anything but a couple random folders on the hard drive.
    there's a link with a zip file to DIY install if you have problems with the installer. however, I only see .exe, which is a windows file? and no real way to use that, not sure where to drop those files.
    just need some help getting this to work.
    May 2019
    Quote Originally Posted by Higgs Boson View Post
    Same here. I tried the Mac manual install, pointing the app to the templates etc. Copied the *.app file over and still barks at me when launching. In for a solution
    Edit: looks like it hasn't been fixed. I've tried this as well.
    Jul 2014
    39.735034, -103.894459
    763
    The manual install ZIP file contains both Windows and Mac versions, so Mac users will want to simply ignore all the .exe and .dll files.
    Fortunately, the process is fairly simple for Mac, albeit slightly confusing because what you want here are the two that are both named "RaceRender 3"... One is a folder containing templates and styles, which you should drag into your own user "Documents" folder. The other is the actual application (has a .app extension but you usually wont see that), and if you drag that into your computer's main "Applications" folder, it will then appear in Launchpad. Alternatively, you can put it on your desktop or wherever else and launch it directly from there.
    As for the Mac installer... yeah, that has unfortunately become increasingly problematic and Apple has since abandoned the tool that creates it, so we'll probably replace it at some point. It does still work in many cases, but seems to have the problem happen most when applying an update on top of an existing installation, although trying it repeatedly sometimes works (same for rebooting the computer and trying again). It acts a bit like some sort of race condition that we aren't given any control over. I share your frustrations. We may end up just going to the .dmg approach that so many other Mac apps use, although that's really just a manual install process in disguise and has its own drawbacks.
    Mar 2010
    Texas Hill Country
    3,161
    thank you
    Jun 2019
    Quote Originally Posted by Weston@HPTuners View Post
    I've also been using Race Render for years without issues, but with the last two updates the installer has failed to work. Took me a while to work out where the Mac files were in amongst the Windows stuff in the install.zip!
    Have you looked at the option of using the Mac App Store? That way update would be delivered direct to your customers, rather than us having to check and then download. I know getting that up and running could be tricky; you'd had to make the program free on the App Store for a very limited period so that we could all "switch" over to that system. Once done, it would work seamlessly.
    Most of my Mac apps work this way now. Just a thought!
