So I understand injection timing is a big deal. Is there any we can steal on the stock cam for additional fueling for E85? Seems like most that do it don't want to give away there secrets. Any one willing to share? Is it something I can search for?
With stock camshaft in a boosted setup in the high RPMs above 5000 and in your WOT g/cyl aim for 335-340 if you have a stock LT1/L86/L83.
Then interpolate between 3000 to 5000 RPM.
This is simple for a stock cam vehicle.
When you install a cam you can advance your SOI further specific to your cam specs... use your intake duration and intake centerline to calculate when you can start your injection but I do not exceed 360 SOI.
Cam card will dictate what you do with SOI (or Atleast when is optimum time to Inject amd not waste fuel)
Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
Thanks guys any idea how to get around the pressure drop? I tossed in some E85 and the pressure drops big time at full throttle yet the Injector duty cycle is only 48%. You could tell it wasn't getting fuel. It is an LT4 car
Yeah its at 9-10. What's the max I can get out of them? I assumed with this big of a pressure drop I was going to need to pour some 93 back in the car to stable it off some.
Are you saying 5 is the max so I'm asking for double the fuel they can provide?
The car was at 55% ethanol at the time. I've scaled it back some it's around 35% now, I've opened the injectors a bit more and we thinking I'd at least test it to see where its at. I'll scale back the ethanol as needed. That was the plan from the first place, I just though it would take a bit more before leaning out. I think this car is just a freak from the factory. It was making significantly more power on our dyno then any other ZL1 has by a large margin. It put down 577 box stock and the last one we tested put down 519 with an intake on it already. Thanks for the quick lesson guys. Higgs and Ben at it again
Zl1 Lt4
dino033 564.hpl
